Can you run 2 or 4 drives on raid as strip and use the regular ide for other hard drives and cd's and so on?
I know you can run 2 or 4 but how bout 3 drives on raid as strip? NOT! right?
System performance help!
Memory module i have. "1 pc 256"
Tonicom S.I.M. BGA PC166 Memory(168 Pin - 3.3 Volt - Unbuffered)
Cas 2 Latency at PC133 & PC150 - Cas 3 Latency at PC166
(6 Layer Single Bank - Low Profile Module Boards For Extremely Low Signal Noise)
Can i run my memory at 150 while leaving everything else (cpu) at default spec's?
Memory setting is at "Dimm0 (tras-trp-trcd) fastest (5-2-2)"
SDRAM Cycle length at (2)
Bank interleaving (?)
DRAM Page Module (?)
Cpu settings help!
Spread Spectrum Modulated ? Disable/enable ?, and what is this anyway?
Cpu clock at (133) Type in here is sooooooooo cool!
Cpu Clock ratio is on "Auto" ??
Cpu Vcore setting on "Auto" ?? VIA Hardware Monitor say its running 1.82.
What Vcore do i run my [email protected] at?
System temps question: What is normal or good cpu and system temps?
Cpu settings help!
