System Specs:
AMD 1200mhz
kk266r v1.2
256mb stick of tonicom pc166
Elsa Geforce2 32mb at 225/390
After testing my system the best performance I can get out of it and have it remain stable for several hours of high cpu load (q3arena and unreal) is 160 bus with cas2, 4 way interleave, turbo memory timings, i/o at +5%
The sisoft sandra scores are: alu = 655 / fpu = 747
If i disable the turbo function I can run at about 165.
For those of you interested in the raid performance I have 2 ibm 7200 rpm 60gb drives running in stripping mode. They are set up on the same channel as master and slave and the Acoustic management is disabled for both. HD tach 2.61 scored them at 41000 read and sisoft scored them at 36600. I can't wait until next tuesday when I receive my 1.2 266 cpu and RMA mine back (damn thing wont break 1280 mhz
) and slap in Falcon4 and see what this puppy can really do
UPDATE
Actually I can get it up to near 170 now if I underclock my cpu. Either my cpu is a dog or my 300 watt power supply isn't getting the job done. My new cpu will arrive next tuesday and if that doesn't work I guess i'll have to shell out some more bread for a better power supply. ANyone have this happen to them?
AMD 1200mhz
kk266r v1.2
UPDATE
