Iwill KK266 Voltage jumpers
rocknindy
I just put my Iwill in last nite, i know the manual shows the jumpers but the jumper has 2 rows of 3 pins, which row do you use to increase the voltage? This board rocks so far, need more power ah ah ah ah
There is only one voltage jumper, it is the 3.3V io jumper for graphics card and memory. The manual is incorrect, it is not located below the powerheader, but to the right of the memory banks. Use an additional jumper to raise vio if you experience instability of the graphics card or the memory.
Yo
