I"m gonna jump in here to see if i can get some help
I'm also running iwill xp333r, with 512 megs of pc2700 kingmax 5ns ram
I get ~ 1400-1600 mb/s in sandra
I have messed with WCPRSET/EDIT before, and changing the registers mentioned. The problem is this - it seems if i set the mem. timings to "FAST" in bios, it has the same effect as changing those registers (get 1800 - 1950 or so in sandra)
However, with the FAST timing enabled, i can't run faster than 143 fsb or so. or maybe it was 147, right around there. That was THE setting holding me back, it runs performance enabled, CAS 2, 4 - way interleave etc... all fine, just that mem timing. I thought this RAM should handle it (rated pc2700 at CAS 2) and the ram runs up to 192 CAS 2 fine, haven't tested higher.
So basically I was getting the same mem score at ~ 147 fsb with FAST timing or with registers changed in WCPRSET (if i put timing to FAST the registers are already modified for performance) as I do running the NORMAL timing in bios at say 166 - 170 fsb.
Any suggestions to improve. I have the 4-11 bios. once i tried taking out one stick of ram, then the other, didn't seem to make a diff. i thought it was a board issue then. but that was a while ago...
