JB Weld.
Borisw37
I have heard of JB Weld, saw it in stores but never tried it. Is it a good alternative to soldering. I need to solder copper tube extensions to a brass/copper heatercore. Any precuations or tips for using it?
jb weld is all that's holding this pos waterblock together:
seems like good stuff so far..(I need to cut down on the pics posting I know.. i'm trying. really.)
JBweld is great stuff. VERY strong. Just make sure you let it cure for 12 hours before use
I have worked with JBweld and yes, it is very strong but its VERY helpful to rough up the surfaces to give it somthing to "grab". Also make sure the contact areas are very clean. I have used a small halogen lamp and boy does that cook it good...hardens much faster and seems a bit harder than even normal.
I would prefer soldering nine times out of ten, Only use jb weld when you cant solder(copper and plastic, aluminum etc.)
Jon
Good to know.
I wonder if it works well with epoxy.
Suma.
