Swatdog said:Swweet man... Can't wait to see results, but BECAREFUL!!! Don't burn anything up. Watch your temps EXTREMELY closely. I would suggest setting the internal PC alarm to sound once your CPU goes over 60C just to be safe because 60C on WC, is not good.![]()
AlanD911 said:UPDATE:
Hey guys ive been playing around in the bios and so far I've gotten the HTT to 268! But then when i boot into windows it automatically restarts. anyone know how to fix that
AlanD911 said:are u talking about the cpu temp or case temp? cuz case temp is always in the 40s and cpu temp is always in the 30s lol
Im wondering what is the use of this chipset voltage controller it doesnt seem to give meany higher HTT when i increase the volts on itthe LDT one helps tho
DarkAssassin said:Question: I noticed in the earlier pics that your two ram sticks were side by side. I only have a 3 dimm xp supporting board w/ dual channel, but shouldn't the ram be paired by the colors of the slots? I dunno, check you documentation.
AlanD911 said:Time for 24 hour prime95 testing be back in a day![]()
CanadianTSi said:AMD64's love tight timmings, you should find the highest stable speed your memory will do 2-2-2 and then use dividers to get your CPU up around 2700mhz.
