24/7 is whenever its on to me, for the record...not literally on 24/7.
1.45v would be my limit and Im not a cautious person. I run my CPU at 4.5Ghz 1.2v (nothing I play needs even that).
Why not be the guinea pig? Try it there since temps are in order... report back in a year or sooner if it happens to croak.
Solid copy on that. I'm not that cautious either. I'm not saying that it doesn't matter to me, but I'm expecting about a year and a half before the next upgrade anyway. Warranty doesn't matter, I've cut the top off of her!
Time to go play around a bit!
LOL! I've thought about it!
That said, I'm going to try 4.8GHz and get it stable if it will be stable under 1.450V.
I didn't have the "Extreme Voltage" option clicked in the BIOS. Not sure if it matters. The descriptions in the bios on some of the options are VERY lacking. Testing 4.8GHz at 1.450V to make sure it is stable at that point. If it is, I'll start taking the voltage down.
Try 5ghz with 1.5v, see how that goes
Are you using Liquid Ultra/Pro/Phobya liquid metal on die? (if not, you should)
5.0GHz at 1.5V will boot but wont prime for more than about 15 minutes before BSOD with 124. I tried that first after delidding and after the base run to see the temperature difference. That was before I enabled "Extreme Voltage" in the BIOS though. The one place I found that had any information on what that option does said it might push the vcore wall back enough to get another multiplier or two. I suppose it's worth a shot again at 5.0GHz.
I'm using Liquid Ultra on both the die to IHS and IHS to water block.
4.8GHz is running at 1.450V (1.440V-1.448V under load according to CPU-Z) with the 27.7 version of Prime95 Blend... temps are 69/76/75/70 on the cores after 50 minutes. Temperature obviously isn't the problem here, it's voltage!
You can bench around 5ghz with under 1.6v...I would NEVER go over 1.6v on air/water. Delidded should do fine, as ED said 1.45v is touted as safe for 24/7 use.
So, do have fun and bench and validate higher with more vcore, but try not to go over 1.55v if at all possible.
?I'm no expert but from what I've been reading after a certain point(1.475~1.5v) no matter how much more volts you add you probably won't beable to oc any higher than what you are at right now.
I say 4.8 is a good oc for 24/7 use, and those temps are nice for 1.45v mine peaks at 90C sometimes, but only when my room reaches 33C ambient.
Yeah 4.8 is definitely overkill for daily use and with exception to FSX, for gaming use as well.
By the way, your username is strangely familiar and I can't for the life of me figure out why. I don't suppose the GT has anything to do with Mustangs does it?
My rig is mainly used for folding, so 4.9 isn't overkill for me
I used to have a mustang, but no, I've had this U/N for probably 8 years, and the GT came from my days playing Gran Turismo... lol
Ahh well, yes 24/7 Folding will certainly require more processing power than my paltry internet surfing and video gaming!
I wonder if I'm mistaking you for one of the guys I know on one of my Mustang forums who has either a similar or the same username.
I used to be in modded mustangs, got banned from there though... lol
Ahh... then you are the same person! Didn't know you got banned though! =\
Now I've gone and hijacked my own thread!
