bigstumagoo (Jun 05, 2001 03:13 a.m.):
ive read the manual at least 3 times plus skimming through to the relevant points and i cant find a single mention of it. the motherboards utility disk comes with a program called easytune3 but upon installation it says its incompatible with my motherboard(which is strange seeing as the disk is for my board) the closest mention to anything like it is a setting in the bios 'chipset feature setup' menu labled as configure timing by speed and not knowing exactly what it does I wont play with it
thanks for the input though
That timing thing you refer to in the chipset features probaby has something to do with your RAM timings or the such, not CPU speed.
Like dunno260 said, check to be sure your CPU is not muliplier locked...most are. The way to tell is by changing multiplier settings and nothing happening (the obvious way, lol), or by looking at the CPU and seeing if the dots labeled L1 are connected. If they are then your CPU is unlocked, if not then you need to unlock your CPU.
Also, check your manual again...it should have info on multiplier settings...probably not far from the section on setting the FSB. Also look on your board for a set of 4-5 jumpers, or maybe dipswitches (not sure waht Gigabyte uses).
Aside from that, the only thing I can think is that the gigabyte board has no multiplier settings and just uses the default locked cpu settings...that may be the case, but like i said, i'm not familiar with the board.
When the boards first came out it was either FIC or Gigabyte that cut off the jumper leads for the multiplier settings (this is a really old memory...anyone know what i'm talking about and can back me up?)...the result of this was no multiplier settings but the contacts for the jumper leads could still be seen in the board...
Well, hope that helped some. Good luck!
Mike
