Just bought a Asus P4PE and a 2.4b(non-c1)
i.t
I killed my KT7 last nite while trying to update the BIOS.. so i couldn't wait for the C1 version.
Bought myself a P4PE.. i haven't seen many people with this Motherboard/ CPU combo..
Can someone tell me their settings on this combo ? and OC speed ?
dxiw
Disabled
i got a 2.53 on that board its awesome fast and all go tit o/c'd to 3ghz..stable with like 1.55 volts on intel stock
jarett
How's your p4pe working out for you ? Personally I'm thinking of buying one. Should I ? Or should I go with the P4B533 ?:confused:
I
i.t
i got the p4pe b/c it was newer and would support the new HT chips coming out
alanticman
I think p4pe is a good board for doing overclock because it supports DDR333(maybe DDR400). And if you really want to try overclock, you may go www.atacom.com to get a C1 chip.
