HERE
I had a 120 blowing on it
via hardware monitor showed ~32 at idle and ~41 running CPU stability test for an hour 1.75v Duron650 @1000. With on board sensor so don't quote me. HERE
Just PB/Sn ROSIN so it would stick.
No the waterblock is just one I made
should have seen the original waterblock it was made out of a metal called Ampco90. I believe it is a berilium copper mix. I took it in to be machined and the guy says. Oh yea that's Ampco brass should only take about an hour=$65 dollars. Calls me up and says it took him all day (this stuf is real gummy) But he was only going to charge me $250. GFY. you would think he would have called and said hey this stuff is tough to cut.
surlyjoe (Mar 04, 2001 02:31 p.m.):
HAHHAHA , thats awesome!!, ,except I used aluminum cable w/copper ,and didnt get very good results ,so I abandoned the idea
a good hole saw 1'1/4" and a drill press
a chop saw
with proper size copper plate I could make about a dozen at a time
belt sander for lapping
then some hand work
about 1 hour
