just finished running Prime95 torture test for 24 hours, this temps OK?
Kino
Panamá, Ciudad de Panamá
i just finished running the Prime95 torture test for 24 hours, and this were my temps
46°C CPU temp
59°C Board Temp
52°C PSU Temp
it always went 1 or 2°C off this temps but always more less around em
are theese ok, i mean, that mobo looks hot, and the top of my case feels preety "warm"
Those temps aren't right.. Your casae temp cannot be lower than your CPU temp, so your case temp is 46c (get some fans!!!!) and your CPU is either 52c or 59c. Get some airflow in that case, it'll help you tons.
could it be my temp monitoring chip that messed up then?
casue im using MBmonitor, Speedfan and Sisoft sandra to monitor thse things and they all turn the same
oh i checked in BIOS aswell
Kino said:
uh-uh.. those are the real temps man... and yes im getting a case soon, mine only has room for like 2 60mm fans on front and 1 on the back
btw this is the case im lookin into http://www.axiontech.com/prdt.php?item=33505&spc=Features / Specs&zipcode=33166
and yes i know the PSU is poop im orderin an enermax already
I'm not saying they're not real, I'm saying they're not labled right.
That's a really nice case! Not expensive, either. :)
Is your zip code 77099 by any chance? :p
