just got cable... need to route it
nerd4life
Houston, Texas
ok,
i looked through the forum and didnt see this question already asked.
i just got roadrunner today but only had them install for one computer so they brought me a cable modem. do any of u use roadrunner and if so can i go buy the cable/dsl router netgear makes ( model RP114 ) so i can route all the computers in my house??
if i do this, how hard is it to setup the router to connect to roadrunner??
thx
rUfUnKy
Ma.
nerd4life said:
ok,
thx
I have a linksys 4 port but they are all pretty easy to set up .every thing you need to know should come in the direction..should be up and running in a half hour or so..
LandShark
Super Shark Moderator
Deep Blue Sea (Maryland)
yes! u certainly could run a router to share the cable modem w/ all ur machines. (well, who don't?!)
and i have a Linksys wireless AP + Router w/ 4 ports Switch. they are fairly easy to setup even if u r not in networking field.
basically, just enter the exact same info in ur PC's network setting to the router's setup page (mostly web base). and set all ur PC to obtain an ip address, so that it will look for a connection (from the router) instead of trying to use it's own.
good luck, and happy browsing w/ ur cable. ;)
XprincoX
bargain hunter
Irvine, CA
yup linksys 4 port router here too, bascally just plug and play. Also just enter the host name and domain name given by the isp, and presto!! :D
rugby
King of Cats Senior
Chicago, IL
All of this information was easily available in my sticky at the top of the forum. You could have saved yourself a bit of time by reading that first.;)
LiGhTBoY
I have a small question:
It's the wall-plug > cable (ADSL in my case) modem > router > PC
OR
Wall-plug > router > PC ?
I mean : do you need to have a modem between the router and the network or just a router?
Thanks
