Just got FarCry how should it be running?
Quattro
Hiya.
Got my new 9800Pro today, haven't been home yet to install it however I bought FarCry today aswell.
How will it run on my system?
AMD 2.3Ghz 32bit
Sapphire 9800Pro
Asus A7N8X-D
512MB 2.5-3-3-11
7200rpm 8mb Maxtor
512k connection
Any other hardware that affects this game?
CircuitBreaker8
Disabled
Silver Spring, MD
Quattro said:
Hiya.
AMD 2.3Ghz 32bit
Sapphire 9800Pro
Asus A7N8X-D
512MB 2.5-3-3-11
7200rpm 8mb Maxtor
512k connection
It will run fine for the most part, but Far Cry loves high memory bandwidth and lots-o-ram.
Quattro
Quattro
I'm planning to upgrade 1gb within the month maybe next week!
Mustanley
You should be able to run all details at "Very High" with the res at 1024x768. Those are the settings I use when playing on the 2nd machine listed in my sig, which is very similar to your specs.
I.M.O.G.
Glorious Leader
Rootstown, OH
You will be laggy occasionally during paging until you get a full 1GB - you can tweak some settings to alleviate this though, or get a full 1GB and run it all out at 1024x768.
