Just got Motherboard, Ram, CPU
ancient
I beg real good, I recieved all assembled. with note saying " I stayed after work and lapped heat sink (last grit 2000), applied artic silver, hand picked ram, CPU and assembled, thats as far as I can help you- Good luck".
Its a KA-266-R, 256Mb DDR ram with 1.3ghz 133mhz TBird.
I will spend the next couple days buried in the manual, plus a couple more lurking this forum, then try to find that darn Soldum case.
Isn't life wonderful
ancient
