Just started the leak test
OCn00b
I put my new setup together tonight and it's not being tested for leaks. I'll probably get up in the morning and go get some zerex super protectant (I think that's what it's called) and replace the current setup. I know it's not as long as most people like but in reality, will a 8 hour leak test be long enough?
Korndog
California
i'll usually test mine for an hour..
best test is pressure test IMO
i'll usually blow in the T line, have my cathode light next to my rig, zerex coolant glows even brighter outside of the tubing so its easy to notice a leak that way.
8hours should be more then enough IMO
Jibjo
Bensenville, Illinois
OCn00b, I recently did just that. Here is a mistake I made: I tested it 24 hrs outside the box without putting on all the clamps, figuring to add them all for real when it was completely installed. No leaks! Installed sys, put on clamps. One, however, was not tight enough, and horror: drip....drip onto the new video card. Only two drops, but what a pain it could have been. So be sure to clamp on tight!
Soja
OC, CA
If you're tubing leaks without clamps then the seal isn't perfect. Clamps should only keep the hose from coming off.
jhl3
NC
Pressure test it like korndog says. IMO that is the best test also.
