Wolfeinstein
Disabled
- May 14, 2003
- CA
I just bought an asus a7n8xmb non deluxe it came with the phoenix bios does anyone know which bios would be the best for it the most stable???? between the two pci slots it says rev 2.0 should i stay with this or get a different one and which one??????
the other question is should i disable my onboard serial port 1-2 and parallel port or not since i use a usb printer,usb joystick,and i wont use the game port either or i should just set it to auto or the default options???????
i have 3 case fans that blow air in to the case and i have 1 that takes it out shouold i get one more fan that takes the air out or not???
thanks guys
thanks guys
