K62 =500 @ 560, & Pelt, good w/ Rain 1.0, no good without.
Rottys-R-Us
Jester
So Cal.USA.
Ok. ****.
K6 2-500
Jetway J-530BF mobo, fsb @ 112 mhz x 5.0= 560.
c/v 2.5. Just instaled my new Pelt setup that came in. It's a AOC ICEBERG Active cooler. model-AC-586,for all K6 it says. 40x40 mm, 12V DC, 2 Amps.
In the pic the higher temp is with pelt and NO "Rain"
Turned rain back on when it hit 43*C :-( With the rain is the lower temp, I read in the forum that Rain shouls NOT be ran with a Pelt. Right now it's @ 40.98*C with just this open. Getting ready to go back down to 550 or 500 with regular K6 HSF. HELP !!!
sorry to say ,your CPU is putting off more heat than your cooler can absorb ,,if you let it run without rain ,it would eventually melt the socket off the mobo ,you need to return it and do some more research before you try extreme cooling again ,,that is if you havent drowned your CPU yet
