Hi guys,
I have just fitted al my gear into a Lian Li PC65 and have been monitoring temps on the board.
I saw the CPU temp shoot up to 52 deg C so have removed the heatsink(Coolermaster Aero 7+)and lapped it and that has now dropped the temps down to something reasonable (32 deg C )
I have noticed though that the system temp has increased previously it was 30ish degrees but now it appears to be up around 45 degs.Now is this sensor mounted under the northbridge on this board is it somewhere else?
Whats an ok system temp?And if this is too high how can I reduce it.
Note I have been using PC Alert 4 that came with the original install cd to monitor the temps but have started fiddling with speedfan as I believe that is more accurate(I went back to PC Alert as I noticed the sys temp increases and thought it may have been a Speedfan problem)
I am sooo confused with this board as it seems no one can really say what the correct temps should be as it seems MSI tweak the temp settings with every Bios release .
Anyway thanks for reading
J
J
