K7S5A is it a good O/C Mobo???
Kendan
Senior Punk
Dark side of hell
It is a good motherboard with very limited overclocking features. You can not change the multiplier or the voltage. You are limited in the FSB choices in the overclocking bios. but it is a stable board that can take SDRAM or DDR Ram. If you want an overclocking board that is low in cost and high in features check out the shuttle AK31 with the kt266a chipset, or the Epox 8KHA+ with the kt266a chipset. The shuttle is the cheaper of the two and both are great overclocking boards. Good luck:D
