K7T-Pro2-A With Duron700
BlackOut
Problem, I want to overclock my duron to at least 900MHz.. but I can't get it any higher than 800MHz, when I set the multiplier to like 9x100, it runs at 800MHz, same goes for 10x100 and 11x100, I have tried all voltages.. What should I do, I've got the latest BIOS drivers from MSI, which are specially intended for overclocking...
Please help..
You either forgot to connect your L1 bridges, or you did not connect them properly. Remove the processor from the motherboard and pencil in the L1s, that will unlock the multiplier adjustment.
Nope, I connected them all properly, because I can overclock it, but only to 800MHz.. and when I don't connect the bridges at all, I can't overclock at all.. so they MUST BE connected
"MSI K7TPro2A--Issues"
Ed Stroligo - 12/20/00
Check out the issue in this review from this site.
