K7T266 Pro 2 and 750 Athlon
goman
Ohio
I have the above listed and was going to put it together for Use as a second computer. I already had the 750 and thought it would work. The processor works fine in my other computer but it hands on this board ( according to the D-LED's ) I read on the box of the MOBO that it supports Athlon Duron Athlon XP from 800 to 1800+. Now Im not simple and I do Know that 800 is bigger than 750 but is it so that the board realy wont support this proccesor? Usualy a board will accept slightly smaller chips!?
Any way if it dosent accept it I will buy another PROC. if it will could someone shed some light for me as how to make it work.
Thanks to all who help and to thoughs who don't
it depends if the board supports a 7.5 multiplier
if not you can run the 750@800 by using the 8x multiplier if u can get it into bios to change it
if not youll have to find another cpu
