Kazza freezes my comp
bennieboyq
Kansas City
well i was trying to dl a song the other day ...when all of a sudden.... what do you know my comp freezes up?? i was like what the ... and so i couldnt 3 finger sulute i had to push restart...and then i treid to get back into when windows poped back up .... same thing...it would frezze the whole comp...so i unistalled it and then reinstalled the same setup file...same problem...so i completly deleted all the kazaa files i could find on my comp...then dl the setup again...when i tried this is froze at the would you like to save this file to disk message...so i have been having alot of trouble with it...i ran norton and i have no known viruses...so im stumed i thuoght a fresh install would fix the problem...but it didnt..so yea is anyone else having this problem and what can i do..its so bull..anyway and tips would be nice thanks q..
p.s i have win 2k and a p4 2.2
Are you overclocked? If so, drop back to stock and see if it still does it. If it does . . . Uh . . . I'd just lose Kazaa and go w/ Kazaa Lite :)
kazaa can really hog system resources which is why I don't leave it running too long, definitely try kazaaLITE.
where can i get kazaa lite??? any takers???? it might be my isp cause i get dropped calls all the time ...i want cable so bad!!! this is redickulous...ok well umm im not oc'd right now...and still does it so humm ill surch for a kazaa lite...so till next time
Sometimes here http://www.kazaalite.com/ if not try a google search on it and someone usually has a copy of it laying around.
I recently switched (due to system re-install) and I'm much more pleased with the lite version. I think you will be too, ditch the bloated "regular" version.
ok yea i got kazaalite and i do like it alot better...i dont use any of the other crap that regular kazaa came with so thanks alot...q
Miknow said:
whats kazaalite? is it a smaller version of kazaa?
The way I understood it was that someone found a way to bypass the slew of spyware that they were packaging with Kazaa and just re-distributed it as Kazaa Lite. I could be wrong.
