Kde 3.0
Shock
i am new .. it looks like KDE 3.0 out .. should i get that ..
i am runing mandrake 6.2
Cooler666
Disabled
it was released yesterday and their FTP servers were fully loaded, maybe it is still hard to get it today too
David
Forums Super Moderator
If you are new to linux, dont try upgrading anything like KDE, GNOME, X or the kernel.
I would recomend that you download a more up to date version of Mandrake - 6.2 is pretty old, 8.2 is the newest.
David
Shock said:
LOL .. sorry i mean the new verson 8.2 ..:p
phew! I was going to ask what people were still using 6,2 for :D
I still think that you will be fine with 2,2. You could try downloading KDE 3.0, but I would install it alongside KDE 2.2, in case something goes wrong.
S
Shock
KDE 3.0 just looks good :D
is there a newbie site .. how to install it :cool:
the safe way
i only using linux 2 learn how it works .. understand it :p
so i will like 2 install it .. thats only way i will learn :D
David
the safe way
Newbie tips? Go for RPMs. If possible, get the RPMs for Mandrake 8.x.
If only source is available, it is possible but slightly difficult.
S
Shock
33 files (180mb) .. is that correct ?? i need them all ??
ty 4 all of your help .. and your fast replays :D
David
Even if you dont need all the files, download them all just to be on the safe side.
Samurai_Punch
CP Howze, S. Korea
Most people won't be needing the development files. you'll be able to tell which ones they are by them being the normal package that you'll need then -devel
so you wouldnt necessarily need a file like kde3-devel-3.0-mdk.i5586.rpm but you'd want kde3-3.0.mdk.rpm to install kde3...
S
Shock
hmm is there way 2 del other Desktop Environment . .. that i don't use .. i am startin 2 run out of hd space :(
Samurai_Punch
CP Howze, S. Korea
you can run the a package manager which will let you uninstall packages, you could use something like gnorpm, or some other one, there are some more under configuration>packages or software i think... i can't remember exactly what it is... as i just hosed my system, partially. KDE3 will replace KDE2.2 when you install it, and you wont see an option to select it (KDE2.2), so once you have kde3 running you could also uninstall the kde2.2 packages... i think... you will need to logout/restartx to use kde3 though
kevmarks
Chicago
go for ximian gnome. It totally rocks, and is very easy to upgrade from standard gnome. Well, having said that it was easy for me running redhat. I have never used this madrake stuff....
David
Use Mandrake's package management to remove KDE 2.2
I think it is called RPMDrake, I'm not sure.
Jeff Bolton
Middle Peninsula Virginia
agreed. but there are some things i like about regular gnome better too, like automount of cds, and how audio files will auto preview if you put the mouse over them. ximian doesn't do that.
jeff
Jeff Bolton
that'd be it :)
even if you get kde working, i recdommend downloading ximian to see if that gives you a better liking of gnome. i prefer regular gnome anyways, but ximian makes it more pretty and adds some phat features, especially their redcarpet auto-download/update tool and their evolution email/calendar/scheduling proggy...very cool
jeff
funnyperson1
Senior Member
evolution is pretty good...i preferred Gnome to KDE because for some reason KDE would not allow me to run Folding....i dont know why....
S
Shock
ximian does not work on mandrake 8.2
so i will wait 4 them 2 update .. i will update kde 3.0 :)
