- Jul 12, 2002
Keyboar - Corsair K70 RGB Pro MK 2.0 LP
2 spills, first one was a full glass of water, took it apart, let it dry etc, no issues after.
2nd spill, months later, glass of unsweetened almond milk, mainly on the number pad, took it apart, cleaned it with isopropyl alcohol, going around the entire pcb with a cue tip dipped din alcohol, used dust off, let it dry, but unfortunately my 'd' key is not good, sometimes when I press it, it won't actuate or it will double/triple produce the letter 'd'. I tried with icue on/off, same result. I tried cleaning it more by taking the cap off, dabbing with cue tip/alcohol on the key itself, more dust off...painful just to type this.
The + key on the number pad LED also got messed up, but I'm not too worrried about that and just shut the LED off.
Curious if I missed any cleaning steps or if there's anything else I can try?
I can't see any damage to the pcb when looking with a magnifying glass.
Thank you!
Thank you!
