God I hate it when that happens Especially with such a mild overclock going on. Let me explain; (Bear with me this could get long and ugly!)
Abit KT7AR,
1Ghz T-bird,
256Mb pc133 micron ram.
Geforcr 2 GTS 32Mb
2*20Gig IBM drives,
SOny 40 speed CDROM
Iomega Zip CD
etc.....
I've had this running at 10*133 in the past, but had turned it down cos I was worried about the heat. Afte r putting in three case fans and fitting a thermo engine with delta fan I tried again. This time I tried it slowly: 10*112 fine, then 10*120 fine.... Until I started using it!
Playing Black and white the soound stopped, I quit into windows, and tried to reboot. No joy, on POST the memory counted up OK, drives detected OK, but reported registry errors so wouldn't get into windoze.
Fine me thinks, boot from floppy and fix registry. Message: "Floppy Dive Fail (40)" Bugger! Try to boot from CD "ATAPI CD Drive Fail" Big Bugger!. The system asked me to boot in safe mode, Ok says I do it! No says system, your registry is shafted. It left me in a black screen with a funny prompt C> rather than the usual C:\ couldn't enter any DOS commands here, all I got was "File or command does not exist".
Has my Mobo given up the ghost? It seems unlikely that all of my drives would fail in one go. I presume it can't really be a registry error as the drives can't even be read. I cant work out why this happened 120Mz bus should easily be possible and I've done way more before.
Any suggestions before I RMA the board, cos if it aint bust and I send it back they'll charge me a load to look at it.
Thanks in for reading this far.
Mike
Abit KT7AR,
1Ghz T-bird,
Geforcr 2 GTS 32Mb
2*20Gig IBM drives,
SOny 40 speed CDROM
Iomega Zip CD
etc.....
Mike
