- Mar 18, 2003
I feel like i just shot myself in the foot! I managed to kill two of my HDs last nite. I was powering these HDs with a Y-splitter connecteed to a molex. But i wanted to fit the splitter in a tight spot so I took the female plug apart, fit it through the tight spot, then reassembled it. I made sure to see that the 12 and 5 volt lines on the female connection matched the 12 and 5 of the molex... COLORWISE. Meaning, I only went by yellow to yellow, red to red, blacks to blacks. I didnt check to see if they went to the 12 and 5 volt inputs of the HDs. So, everytime I booted up, the computer hung when detecting the drives. Puzzled, I checked that the drives were getting power via multimeter. Solid 5 and solid 12! Finally, as I was about to give up, I checked out the configuration of the way a regular molex went into another HD and to my horror, it was REVERSED! My splitter fed the 12V to the 5V line of the HDs and vice versa! Damn near had a heart attack. dug around for another splitter I had picked the same time I bought with the one in use and compared the two. As it turns out, color coding didnt matter. So, molex yellow(12) fed splitter red and molex red(5) fed splitter yellow for the sound and unmodified splitter. I went by color code and connected molex to splitter, yellow to yellow and red to red when it should have been yellow to red and red to yellow.
Hard lesson I learned today, should have been more careful and should have doubled check ALL my work before flicking on the switch. Lost a WD1200JB and a samsung 40G spinpoint
plugged into seperate molex hoping the computing gods may have spared my HDs, but to no avail... they have left me.
anyone know if they can be salvaged datawise as well as hardwarewise? this is only assumption, but wouldnt the 12V power the motor and the 5V power the logic... so if I overvolted the logic, would it be possible to just contact my respective manufacturers for logic repair/replace ie. the underside pcb?
I was also thinking that since I can obtain an identical WD1200JB, can i just switch pcb to get my dead one working to offload data? provided , of course, that the logic is the onlything wrong with it.
anyways, I just wanted to share some of my misfortune so that to enlighted the few that are not... to not do what did.
