Kingston DDR-PC2100
Talibano
Hi all,
I know that Corsair and Crucial are top memories, but in my country they are very expensive and I can’t buy it, unfortunately.
Therefore, I wish to ask if someone knows if Kingston’s PC2100-DDR memory modules are good enough for soft overclocking (CAS2 and SPD settings), since they are cheaper for me.
thanks
The Doors
Vesuvius Senior Ocer
Athens - Greece
Hi Talibano, welcome to the Forum,
I suggest you to go with Crucial PC2100 Unbuffered, that generally can go up to 150Mhz and more, for me are the best of all for the $ ;)
Adriano
RED Hot Machine
Inactive Moderator
Welcome to the forums.
I use Kingmax 2100 and it runs at cas2 no problems. If you intend to overclock, knigmax works better with the ddr voltage at stock.
