Today I will present memory which is already for couple of months on our market but is for sure interesting - HyperX FURY 4x4GB DDR4-2666 CL15 1.20V - PN: HX426C15FBK4/16
I was already testing 32GB DDR4-2400 which was overclocking good but I wanted to take a look at higher clocked 16GB version and Kingson gave me that chance.
Below you can check how ASUS Rampage V Extreme sees memory profiles. As you see "standard" SPD profile is exactly the same as XMP so it's probably the most user friendly memory on the market. Simply, you install memory and it's working as declared. If motherboard has no issues to read SPD profile, then is no need to set anything else in BIOS.
Also screenshot at default settings DDR4-2666 15-17-17-35 CR2 1.20V:
