kingston KNR7TXD help!!
firebird79
do anyone using this router? did you sucessfully put up a web server by using port 80? i setup a server and this router won't let me use the default port. i had to use other higher range port(1000 up) to connect it. ie, the server ip is 192.168.xx.xx, i use the option in the router to port forward the incoming connect from port 10000 to the server(port 80). the question is, how i gonna set to make me connect directly to port 80 from wan?
