V
Van
Guest
Having some problems with a system I just built and was wondering if anyone had any suggestions...But first, the specs
Thunderbird 1.2/266
Iwill kk266 v1.2
256 MB Crucial PC133 cas2
Leadtek/Winfast GeForce 2 Pro 32 MB
IBM 30 GB UDMA/100
Asus 50x CD-ROM
Lastest 4in1 drivers
0426 Bios
DirectX 8.0a
Latest Detonator drivers
Windows 98 (not se)
These are only components installed right now. What appears to be happening is that the hardware 3D acceleration is not working. Any time an application that uses 3d acceleration (i.e. games and 3DMark)is started the computer completely freezes. Cannot even alt-ctrl-del out. System runs all SiSoft Sandra benchmarks perfectly and is completely stable otherwise. When I turn off hardware acceleration through the the Display-Advanced-Performance tab, games that would not run previously but do not require hardware acceleration run fine, albeit with poor graphics. I have already reformatted and reinstalled everything once, and changed pretty much every bios setting related to graphics. Does anyone have any ideas, or at least a place to post this where someone might know what's going on?
Thanks
Thunderbird 1.2/266
Iwill kk266 v1.2
IBM 30 GB UDMA/100
Asus 50x CD-ROM
0426 Bios
DirectX 8.0a
Windows 98 (not se)
Thanks
