KK266 USB ports not working
Patch
Bavaria, GE
Hello all! I have a KK266, and just got a device that uses a usb plug (never had usb hooked up on this mobo before) anyway, the device should be emulating a usb keyboard, but is not working on this machine.... is there something I have to do to turn the usb ports on? Thanks.... Jim:burn:
Update... I have found that the usb is disabled from the factory, and I have never enabled it... went into bios to find it... and voi....huh?!? cannot find a way to enable usb through the bios... has anyone got any ideas? thanks Jim:burn:
its in the bios...
dont forget to scroll all the way down... you might not see it otherwise...
