Knoppix help needed
glebka11
Canada
Hey ppl.
I have a problem w/ my knoppix.
Well, when it runs from cd, the resolution is 640*480, and when i change it it askes for restarting session. when i restart, guess what? it runs the previos settings from cd...
What should i do? i really need 1600*1200 :(
Christoph
JAPH Senior
Redmond, WA
When you boot Knoppix, it drops you to a splash screen with a command prompt before it loads the kernel. Just push f2 at that screen and it will give you a list of options to change how Knoppix boots.
Arkaine23
Captain Random Senior Evil
Enter this at the first prompt when booting from the CD:
knoppix screen=1600x1200
glebka11
glebka11
Canada
kool, ive done it... it works :)
do you know if i can install appz in knoppix (like to RAM or something) ?
Arkaine23
yes, but its some work sincer you have to rewrite the make files and install from source. there are some scripts on knoppix.net to install certain thngs to ram such as 3d nvidia and Ati drivers or f-prot, flash-plugins, etc.
Arkaine23
You can remaster a knoppix CD and install all the apps on it you want, and remove the ones you don't want.
