Koolance compression fittings
caddi daddi
Godzilla to ant hills
Am I the only one that finds Koolance compression fittings bulky?
these are for 3/8x1/2 soft tube, they are REALLY, REALLY nice pieces but compared to the xspc parts, REALLY bulky.
On my raystorm block they clear each other by about 1/4 inch where the xspc fittings in my other rigs clear by a mile.
caddi daddi
caddi daddi
they do feel nice and heavy in the hand.
this build is getting all chrome.
bassnut
Premium Member
They are a nice fitting ..... with the added bonus you can use a wrench to tighten them a bit instead of busting up your fingers on the knurled fittings. I like the look of these fitting in black ...... not a chrome lover. I guess I got tiered of polishing the chrome on my bike ...... or something like that.
caddi daddi
caddi daddi
what are you guys doing for system drains in systems that can't be removed as a complete unit?
I have my rad mounted so the ports are at the bottom.
I've got two "T"s and have the compression fittings pointed up for the system tubes and barbs pointed straight out, i was going to put two drain hoses that i can just flop out the side to drain the system and just flop them under the motherboard tray when not draining it.
it is not going to look good like that.
I have time because I'm waiting for some unimportant pieces like, psu, cable kit, operating system to arrive.
and i kind of have to have some chrome.
the case is red, a color i don't see so it's lots and lots of grey, I will use blue tube and a blue led exhaust fan and the chrome will be sparkly so i will get it enjoy it some.
bassnut
Premium Member
I use a T connection and pass the tube out through the back wall of the case with a special fitting ...... Im off to bed now but will get you a pick in the am.
Edit .....
You can see my drain line to the back of the case .........
Where I pass the drain line through . Just pop off the cap and add an extension tube and you can drain into a bowl.
bassnut
Premium Member
Something else you can do if you have extra ports on your rad is run your drain of one of them.
caddi daddi
caddi daddi
this is going to be one of those builds that the cooling system will not be able to be removed as a unit, I have the room so I am throwing in everything I have laying around, EG, I am using a dual bay res/pump combo but, also throwing in a 250ML watertank res.
I will look at a through hull like bassnut uses.
Tgrable
Minneapolis, MN
Speaking of bulky fittings I got a set of swiftech ones I added to my build today and they are massive. They basically touch on my reservoir they are so wide.
