Koolance mod
MyEpoxDied
I am thinking about modding my koolance case it is the pc2-2. What i want to do is remove the pumps, resevoir, and waterblock and replace them with better parts. For the pump i would like an eheim pump that will work with 5/8" hose which would be best? Also how would i go about filling the system up with water. Last question, how, without a resevoir, does the water get cooled in the cycle it seems like it has no idle time to cool. I know i'm a newb at this but thx for the help :).
lonlyintelguy
dont mod your koolance its a waste of money.
I would just spend your money on getting some good fans for cooling the case. Koolances dont have good interal air cooling so improve that. Also look into that new 200 watt water block. But dont waste ur money on a new pumping system.
trey_w
North Texas
i own a koolance also. dont wast your money ripping it apart
you should of built your own
i wish i had
dont get me wrong, i love my koolane, but it has its limitations
