KT7 GREAT PROBLEM
Vovan
Germany
Hi!
I've bought KT7 and got Duron 700.
The speed I set in SoftSwitch - doesn't applies and if i set 850 it is usual 700.
I tried to mark with pencil the CPU switches:
L1 - no effect
L2 - aleady all connected
L3 - Hangs!
L4 - no effect
If you can help me I will be very grateful!!!!!!!!
Is that the Abit KT7 or ??
If you got the Abit KT7 you should connect all the L1's and use the 'user define' setting in soft menu.
