kt7a and delta black label
J
JEFF
Guest
i saw an earlier post about the black label burning up a fan header.mine came with the three prong fitting for the header.is there much danger of burning up my header on this board.i also have 3 other 60 mm fans on the other headers and a few on the 12 volt circut.
No danger at all mate. I have the black delta on the motherboard connector and its def np.
Rich
Those fan headers are rated for .6 amps and that delta only draws .48 amps so you should be ok. I had one plugged into my MoBo for awhile and had no problems.
