KT7A beta bios
Shep
Senior Member
Marshall, MO
Has anyone tried the beta bios that is supposed to fix the the 686B southbridge and Sblive conflict. Does it work?
havent yet.what probs did u have?mine had lots but i have sb 128 pci.i have fixed it but may do reinstall if it fixes the problems i had.
I had to disable DMA on my cd and Cdr in the bios and windows to keep the system from freezing and the mouse from making noise. I finally had to remove the Sblive to burn a cd, it would give me a bsod during writing. Pulled out the sblive and didn't have any more problems but no sound either.
I've been using BIOS wz110b for a while now and have had no problems.... I use a SB Live Value 2nd Ed. in PCI slot 4 so until I have some problems I am not going to change it.
SickBoy
