Well, my odyssey with this new board and CPU continues...
I've got Windows 98 running rock-solid now, but I have yet to be able to run Windows 2000 on my KT7A at all. My old install won't even boot (I get an "inaccessible boot device" stop error and none of the fixes I've tried have worked) and even a brand new install locks up after a few minutes every time. This happens whether I'm running overclocked or not. It also happens with or without the 4-in-1 Via drivers, and it's happened now both before and after installing the Win2K service pack.
My first question is, does *anyone* have a suggestion of any kind for getting my old install to work? I even merged some registry info regarding Via drivers into my registry before swapping motherboards at the MS web site's suggestion, but it didn't work. Of course, not being able to get into W2K at all now, there's nothing else I can do from within the OS - though I can move files and stuff around from Win98.
Failing that, what could be causing the lockups in my new install, even when running at fail-safe defaults? If I can get it to quit locking up I can at least migrate my programs and data over to the new install, but as long as it's locking up like that I'm forced to use Win98. That's the funny thing about it; I've tried every stress test I can think of to break my system under 98 and it won't happen, but even doing something simple like scrolling the window in IE under my new 2K install eventually freezes it. And I'm using the same drivers I was using before, which always worked fine in the past.
Argh.
Argh.
