M
Me
Guest
KT7/KT7-RAID/KT7A/KT7A-RAID/KT7E. ftp://ftp.abit.com.tw/pub/beta/kt7/bios/kt7_3r01.zip
has anyone tried overclocking with the 1.4 chip and this new bios??? I need to know because im looking to buy either a kt7a or a kk266 iwill.1. Update BIOS code.
2. Enhance ISA PnP compatibility.
3. Enhance SCSI adapters compatibility.
4. Add 1400(133) Athlon support for KT7A/KT7A-RAID.
5. Add new option "1200 above" for high speed Athlons with 100FSB.
KT7/KT7-RAID/KT7A/KT7A-RAID/KT7E only support 1.4G(100) Athlon
with L1 bridges disconnected. Check L1 before you buy a CPU please!
6. For Creative SBLive 5.1 sound card users, you may try these
options while experience sound quality issue.
.PCI master read caching, default setting=Disabled
.PCI master time-out, Default setting=1
Setting above options to Disabled/3 will lead to the same
result with VIA Latency patch V0.14 and may help SB Live 5.1
sound issue. If the system experiences low performance after
these settings, enable the "PCI master read caching" please.
7. Update HPT BIOS to 1.20.0612 for KT7-RAID/KT7A-RAID. This BIOS
version is also for non RAID boards and HPT BIOS will be
automatically disabled while RAID controller chip not detected.
8. BIOS compile date: 06/26/2001
