- Dec 22, 2000
Well, luck of the draw! TWICE! I simply can't load Win2k at the default speed of 10x133 (33 pci) no matter what voltages or ram timings I load. I have now gotten two defective or inferior KT7A-R's....I started suspecting my new 1.33 AXIA, but we popped it into another machine and it performed perfect all the way to 1425 at stock voltage! So the CPU is not the issue.
So I think, ok something I did on my rig is causing the problem. I started over, left everything out except for mobo, ram, and vid card and one hard drive. ALL default settings. NADA! NOTHING! It will post at 1333 but as soon as it tries to load windows it BSOD's or gives an error that the ntoskrnl is corrupt. This IS a fresh install of Win2k, I had to run the machine at 1ghz just to load the OS. RAM is Kingmax pc150 that I used in my last Intel board (CUSL2) at 146mhz CAS2 and also in my previous KT7 mobo at 133+ CAS2 (see the old rig at http://therapture.is.dreaming.org ).
I finally managed to get it to run at 12x110 but stability is a sore spot. Random crashes, freezes, and BSOD's. I tried lower multipliers and even higher bus speeds, but anything over about 115fsb is a no go! At 7x140 it posted but then crashed....
So we get another mobo....SAME FREAKING CRAP, again. I am hard up and pissed off about the lack of quality control on these mobo's. So pissed in fact, that this junk is going back to Newegg, and an Iwill KK266A is replacing it. I have had it with Abit's lack of quality control, I also had an Abit BX133 RAID that would not run a CeleronII 566 at 850. That particular cpu ran at 850 for months in an old Soyo 6vba133 mobo with never a hang or crash. Abit has screwed me too many times now.
They are getting no more money from me. Iwill, here I come.
Any success stories on these KK266's?
