I am having problems with this board as well and I am beginning to think I should return it.
I have an AXIA 266fsb 1.0Ghz chip (7.5 x 133Mhz) - I've unlocked it but can't get it to work with a multiplier between 9.0 and 10.5 with the FSB set at 133MHz. When I try these settings, the board refuses to POST. When I set the multiplier to 11, it will POST quite happily (1463MHz) !!! I've done further testing and can only get those multipliers to "work" when the FSB is between 100 and 122 Mhz, BUT when it POSTs the board reports the multiplier as being something else - BIOS=9/POST=7, BIOS=9.5/POST=7.5, BIOS=10/POST=8.0, BIOS=10.5/POST=8.5. I can use the FSB addition parameter to add a further 6Mhz to the 122, but anything more than that and it refuses to POST again.....!
I have used a few different BIOSes, and all give the same problem.
Is this a problem with the board or with VIA chipset as I've heard similar problems on this site with a MSI K7T ProA as well.....?
My VIA chip has the shiny silver surface, but don't know if this is better or worse!
