That high a temp will impact overclockability of the CPU. Depending upon what your ambient temp in the PC room and the extent of your case airflow, it could be right on, or you could improve upon it considerably with a better HSF and/or case ventilation. I keep my PC room at 20C and my case temp runs about 2C above that. Under that scenario, with a modest HSF, you should be able to keep the CPU down in the 30s under load.
Hoot
