L shaped 90-degree
thedarkdad3
I basically want to run an L however the fittings I have seen (90 degrees) have compression on one end and thread on other end. I need the tubes to connect on both end thus have compression on both ends.
am i missing something here?
GTXJackBauer
USA
You don't want to route your loop as illustrated with both lines. For example, you can go from radiator > CPU > GPU > Drain? > Rad/Res/Pump combo.
When you talk about tubing, are you referring to soft or hard? If soft, have a look at this image of my build where I use compression fittings, angles and extenders as well as a "L-shape" route from the CPU to GPU.
GTXJackBauer
USA
I'm sorry, I'm completely misunderstanding with what you're saying.
Suppressor1137
Get hard tubing if you want it to be all straight lines like that. Just know that every additional connection is another potential leak point.
thedarkdad3
thedarkdad3
gonna hold off on harline as that would require an entire new setup. ^ ^^ ^
batboy
Senior Moment
Kansas, USA
Are you saying you can't find this fitting?
Alphacool HT 16mm HardTube compression fitting 90° L-connector
Jeff G
I'm also not seeing why that would be needed. Are you just trying to add the GPU into your already existent CPU loop? You would just take a line going from the output of the CPU block to the input of the GPU block. Then outlet of the GPU block to the same spot the current output of the CPU block goes.
With your system, lines go like this:
- Outlet of the pump/res/rad combo goes to inlet of the CPU block.
- Outlet of the CPU block goes to inlet of the GPU block.
- Outlet of the GPU block goes back to the pump/res/rad combo.
No need for any special fittings, and the more you add in the more restriction you add and the greater chance of leak you get.
Keep it simple, and use the least amount of hose and fittings possible.
