Mr B said:I don't know....maybe I'm missing something here....
I understand the concept, in which you're basically fooling the CPU and board into thinking it's a 2700+. But how is this going to help you if the chip maxes out at say, 11 x 205, or the DDR you have just doesn't want to go past 210, no matter what voltage you put to it??
How does changing the "default speed" effect the overall overclock and add more headroom to either the CPU or DDR??
Just curious....
q149 said:
There is really no good explanation, it's just an issue with nf7 rev 2.0 boards.. You can only get really high FSB with a default 333 fsb cpu. The earlier revision nf7's had the opposite problem, you needed a default 266 fsb cpu to get really high FSB.
q149 said:Np, good luck. I have an NF7 coming that i should get tomorrow or moday.. hopefully i can go well above and beyond my 235 limit on my 8rda. I will post my results before/after L12 mod and before/after vdd/vdimm mods. There is 2 ways to do the L12 mod btw if it hasn't been mentioned. You can connect 2 pins on the cpu or 2 holes in the cpu socket, or you can connect the 2nd bridge to the left of where it says L12 on the cpu(3rd bridge).
hitechjb1 said:NF7-S rev 2.0 FSB_Sense 166 and 200 mod (from 133) test results
Did the FSB_Sense mod for setting default FSB from 133 to 200 for a Tbred B 1700+ DLT3c.
Reset CMOS, the NF7-S rev 2.0 system booted up. The default bios showed the CPU as a 3200+ 200 MHz FSB, very interesting.
The FSB_Sense mod for 133 to 166 helped stable FSB from 215 to 232+. Chipset Vdd 1.7V. PC3500 C2 6-3-3-2.
These are the highest FSB attained from the 200 mod, and no noticeable improvement (on max FSB) from the 166 mod.
FSB is running 3DMark01/03 stable at
3DMark 01/03 w/ 8500 128 MB, 275/275
Single channel:
238 MHz x 9, PC3500 C2 512 MB x 1 SC, 6-3-3-3, 2.9 V,
Sandra BW efficiency 86-87% (e.g. 3290/2975) <---- highest
3DMark 01 10457
3DMark 03 1544
234 MHz x 9, PC3500 C2 512 MB x 1 SC, 6-3-3-2, 2.9 V,
Sandra BW efficency 87-88% (e.g. 3278/2963)
3DMark 01 10521 <---- highest
3DMark 03 1551 <---- highest
228 MHz x 9, PC3500 C2 512 MB x 1 SC, 6-3-3-2, 2.9 V,
Sandra BW efficency 87-88% (e.g. 3218/2900)
3DMark 01 10335
3DMark 03 1540
Dual channel:
228 MHz x 9, PC3500 C2 512 MB x 2 DC, 6-3-3-2, 2.9 V,
Sandra BW efficiency 88-89% (e.g. 3222/2961)
3DMark 01 10451
3DMark 03 1548
Still testing, ...
- DC loses about 5-10 MHz from SC, as expected.
- But the Sandra BW efficiency 87-89% seems to be low compared to 95% seen mostly reported ??
(For the same memory module, same timing, I can get 95% memory efficiency from A7N8X-DLX SC).
- Also the performance from DC just ties or slightly worse than the 5-10 MHz higher FSB from the SC.
- Using NF7-S rev 2.0 BIOS 1.7, Nvidia chipset driver 2.45
As shown above, have not seen a difference in highest FSB attained between the 166 mod and the 200 mod. But a big difference from default 133 FSB.
One thing must point out is that:
Currently, CPU is running at slow speed around 2 GHz 1.55V to 2.2 GHz 1.7 V (because using stock HSF).
Have to see whether the FSB_Sense mod affects CPU's full overclocking speed.
hitechjb1 said:I found that there are quite a few inconsistent settings reported on the NF7-S rev 2.0, maybe related to CPU, ...
1. Some find the FSB_Sense (or L12) 166/200 mod works, some don't.
For those that seems to work (10-15+ FSB improvement, like my case), are those who get low FSB (under 215 MHz) to begin with. There is no difference between the 166 and the 200 mod on helping max FSB in my case.
After the 166/200 mod, I can now do 228 MHz DC, 230+ MHz SC, PC3500 C2 512MB x 2 memory at 6-3-3-2 @2.9V, Vdd at 1.7 V.
Those who already do 220+ FSB, no much help from the mod.
2. Some say the CPU Interface has to be ENABLE, some say NO. In my case, if CPU Interface is ENABLE, system cannot even boot.
Some say disabling CPU Interface would help max FSB a lot, there is no help on FSB at all in my situation.
3. My Sandra memory bandwidth efficiency is only 87-89%, low compared to many reported 95%. Not much difference before and after the FSB_Sense 166/200 mod.
It looks like the NF7-S rev 2.0 behaves very differently in many cases with CPU, maybe memory, ... I don't yet have any idea whether it is BIOS, CPU, motherboard, ... related.
hitechjb1, the CPU Interface being On will boost your memory bandwidth/throughput. CPU Interface being turned off is giving you lack in your memory performance right now. CPU Interface acts similar to the CPU Fast Decode, found in Via KT266/333/400 chipset based boards. If you could manage to enable that, that would be great.hitechjb1 said:I cannot boot with CPU Interface Enable.
I tried many things, my memory efficiency is low, only 87-89%. I tried bios 1.6 and 1.7 same things. Also different chipset drivers, 2.03 and 2.45, same thing.
