surfinguru said:
Hey Bonka, are you still stuck at 128fsb/1.8 vcore? After getting the vid pin thing to work I'm in the same boat. 128fsb works great, anything over and it starts getting flakey. Are you still air cooling? I'm using the Swifty MCX370's with the Pabst fan and get about the same temps. Since I ordered one of those Innovatek cooling kits, which should be here this Friday, I'm hoping the additional cooling will help me get that magic 133 mark. One last question for ya, what divider/mem settings are you using? I don't seem to have any changes in stability whether it's 3:3:1, 2-7/9-2-2; 4:3:1, 2-7/9-2-2; or 3:3:1, 2-7/9-2-2. Only thing I get is the little statement that says "CAS Timing should be 3" or something like that when ever I try to use the 4:4:1 setting. This divsor thing seems "abit" screwy to me.
(No pun intended
Very Interesting! I'm EXACTLY having the same problems as you. My chip still tops out at 128fsb 1.8v. I personally doubt cooling is the problem. I had planned to go towards watercooling but that will be on hold as I will soon get myself the ThermalRight AX-7. Myabe strap on the 80CFM Delta as well.
I'm using the 4:4:1 dividers. Although I've never tried using the 3:3:1 dividers, I'm certain my computer won't be able to cope with it. My memory timings are set to the fastest speed possible, 2-2-2 5/7. Strange thing though in Sandra, my memory scores are in the 400's, which seem surprisingly low, even for cheap Micron/Samsung RAM. I'll probably do another benchy to update my results.
So far, since I got my Celly, this sucker refuses to go any higher. I am almost convinced that this is a crappy chip. Temps are not an issue, even though, at times, they run in the 40's idling. Go figure.
Let's keep in touch. Perhaps you'll have better luck than me!
