Lan or Non-Lan
DiaperGravy
Kingston WA.
I'm not sure which "version" of board you have such as >>>
K7S5A V1.X (SiS® 735 Chipset)
K7S5A V3.X (SiS® 735 Chipset)
But I think what they are asking you is, "Do you have LAN onboard"? Intergrated ie Non-Removable, if so, then you want to use >chb0325l.rom lan version<
But if you do not have LAN as in you can remove your Network card from your MotherBoard, then you should use >chb0325.rom non-lan Version <
This is pretty self Explanatory: If it's onboard, just change these settings in your BIOS:D
chb0325f.rom lan version with fastwrites enabled But if it's not, then you should "(disable lan in bios Setup to use it on a non-lan board)" for this version.
Does that make any sense? :eh?:
Hope this helps, Good luck:beer:
DpGravy
