- Feb 6, 2003
- washington state
i had my computer running at 1.15v and 1466mhz a while ago, but i moved it to a friends house to play HL on lan and it wouldnt post there. (it worked fine and stable at home) i raised the voltage to 1.2v and it still wouldnt post! so at this point i got ****ed off and put it back at stock on everything. now its up a little higher. 8*200 and 1.45v. thats arbitrary, i didnt test it whatsoever. it does run stable, though. (ran prime all day and all night) i tried putting it back where it was before, and it didnt work even after i brought the computer home. i didnt touch anything inside the computer besides the CMOS jumper during all this time, so i wonder why i lost the undervolting ability i had. can anyone tell me?
(also, what is a good amount of time to run prime and why? should you run prime when you're doing nothing else, and if you dont, should you do it for longer? thx.)
