My question is quite simple. where in the world do you find 1500 - hey I would settle for 800 grit sandpaper!!!!. I live in a city of 5 million , I went to 6 hardware stores and 600 was the best any one had.
I also went to 2 abrasive companies websites no luck.
If i spent three good hours sanding my heatsink( an alpha pal) incuding reusing sandpaper towards the end it gives a finer finish on wood - is that enough?
thanks in advance for any input
Butterboy
Butterboy
