- Apr 5, 2001
- St. Catharines, Ontario Canada
I was just informed that maybe I should Lapp my Volcano II. Does any body have any suggestions on how I should do this? Should I use a fine-grit (600) wet paper, or should I try to dry sand it? What type of sanding block should I use, if any? Should I use thermal compound after I'm done?
