There seems to be some confusion about lapping the copper heat sinks.
Unlike what others have suggested you don't use sandpaper - if your heatsink comes from the manufacturer needed 600 grit sandpaper purhaps you might consider tossing it in the trash...
You use tripoli compound for cutting and then White (maybe red) rouge to finish...
http://www.gomog.com/allmorgan/polishingmetal.html
METAL POLISHING TERMS
by Lorne Goldman
M21 SMOOTH SPECULAR – initial cutting using aluminum oxide compounds.Beginning coarse and finishing with 320 grit, followed by buffing with aluminum oxide buffing compounds.
M22 SPECULAR – cutting with compounds the same an M21finish, followed by a final light buff.
M31 FINE SATIN – wheel or belt polishing with aluminum oxide or silicon carbide abrasives of 180 – 240 grit.
M32 MEDIUM SATIN – same operation as M31, except 120 –180 grit is used.
M33 COARSE SATIN – same operation as M31, except 80 –120 grit is used.
#3 FINISH – a polish obtained by finishing with approx. 100 grit abrasive.More commonly used as a precursor to the final finish.
#4 FINISH – general purpose, bright, clean finish, 150 –240 mesh abrasive used following prior grinding with coarser grit abrasives.
#4 NON-DIRECTIONAL SATIN – 80 – 150 grit with no grain direction.
#4 LONG GRAIN – not the rice but a long continuous grain.
#6 FINISH – a soft satin finish, with lower reflectivity than the #4 finish.Use a medium abrasive oil
#6 FINISH MIRROR BRIGHT – a highly finished product by buffing a surface which hasbeen finely ground but still has grit lines heavier than a #7 finish.
#7 FINISH – a highly reflective finish produced by buffing a surface that has been finely ground, the grit lines are not removed during the final buffing process.
#8 FINISH – standard polished finish. It is quite reflective and is achieved by polishing with successively finer abrasives, then buffing with a fine compound.The surface is basically free of grit lines, although not completely invisible.
Finishing Compounds
Green Rouge
Primarily used in final finish buff operations on stainless steel, steel, brass, aluminum, nickel, and chrome. The green rouge is a chrome oxide, and is considered the best all around luster compound.
White Rouge
The white rouge is the softer than green rouge. Primarily used in the final finish of steel, stainless steel, and zinc. This compound is also a favorite in coloring aluminum and brass.
Red Rouge
Primarily used in the final finish of gold and silver, it is the finest of all rouges. It also produces an excellent finish on brass.
This is what the tripoli and rouge looks like:
http://www.wmhtoolgroup.com/JETWood/Accessories/575850.html
http://www.wmhtoolgroup.com/JETWood/Accessories/575851.html
This stuff might be sold at yur local hardware store in the section with the buffing wheels ...
by Lorne Goldman
Finishing Compounds
Green Rouge
White Rouge
Red Rouge
